michael8554
Electric fan, not the viscous type.
I want to replace the auxiliary drive belt, belt tensioner, and guide pulley, but all the videos are for ML's with the viscous fan.
I think the electric fan and shroud will need to be removed to give enough access to these parts.
I have found one reference that says to unplug the electrics from above, remove two bolts from below, then lower the fan and remove from underneath.
Can anyone confirm this is the correct method?
Michael
Michael
