electric mirrors w124
Discussion in 'Bodywork' started by mattc, Aug 14, 2008.
  1. mattc
    mattc Hardcore MB Enthusiast
    2,579
    Sep 27, 2007
    Midlands
    Car:
    2003 E270 avantgarde, 1994 E320 Coupe
    HI All
    is it possible to lubricate these? My passenger side one moves in all directions but seems a bit jerky when i want to move it outwards.
    matt
  2. grober
    grober MB Club Veteran
    27,600
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    the moveable mirror plate is mounted on a pivot P + two adjusting motors M+M to move it. The motors are attached to the mirror plate via little plastic ball joints. Sounds as if the one that moves the mirror in the horizontal plane has come adrift you need to push the side of the mirror glass nearest the car back firmly into the shell so that it engages with little ball on the end of the motor shaft. You may hear the motor whirring and you will feel a distinct click as the ball on the head of the motor shaft engages with the corresponding socket on the back of the mirror. Its best ( tho probably not necessary) to have the mirror electrically unplugged while you do this.Here's a pic you need to mentally rotate the upper mirror glass ( its back is shown) thro 180 degrees in the horizontal plane to line up with the 2 motor balls marked M on the adjusting motor shown below. Then you are looking at the assembly towards the reflecting surface so to speak.
  3. OP
    OP
    mattc
    2,579
    Sep 27, 2007
    Midlands
    Car:
    Many thanks Graeme
    I will see what I can butcher whilst attempting to "fix" it.
Share This Page
