electric vs petrol hedge trimmers
Discussion in 'OT (OFF Topic) Forums' started by wemorgan, Jun 14, 2011.
  1. wemorgan
    wemorgan MB Enthusiast
    8,120
    Apr 5, 2008
    Car:
    A205 C220d
    Is is possible to compare electric to petrol hedge trimmers?
    The two below cost roughly the same. OK the petrol can cut a maximum 28mm whilst the electric is 21mm, but I'm just after domestic use, so I assume 21mm is sufficient.
    Electric Makita: Makita UH6570/2 65cm 550W Electric Hedge Trimmer | Screwfix.com
    Petrol Ryobi: Ryobi RHT2660DA 60cm 26cc Petrol Hedge Trimmer | Screwfix.com
    I can reach my hedges with an extension cord, so I don't need the range flexibility of a petrol powered one.
    So I'm inclined to buy the electric as it's lighter, quieter and less maintenance (?)
    Have I missed anything that makes the petrol more advantageous?
    Thanks.
  2. Palfrem
    Palfrem MB Enthusiast
    2,957
    Aug 11, 2005
    Solihull, near Birmingham
    Car:
    W124 E36 AMG, G 300 GEL his, SLK 200 hers
    Petrol every time.
    Pros
    Faster, no wires to cut, no power drop on long lead, lasts for ever, cuts thicker branches, long reach blade
    Cons
    Heavier, noisy, smoky if too much two-stroke oil used, expensive by comparison
    I've had one for several years and think it's probably one of the best garden gadgets I possess.
  3. prprandall51
    prprandall51 MB Enthusiast
    2,278
    Feb 1, 2005
    In hiding
    Car:
    Audi
    The petrol can cut a branch that is 33% thicker - that is a significant increase in performance. You would be amazed how thick foliage can become in your average garden hedge.
    The cable of an electric cutter has the uncanny ability to always be in the line of cut, too, and the risk of a severed cable is significantly higher than for a lawnmower.
    I have a petrol hedge trimmer but occasionally have to use an electric one away from home. The petrol-driven cutter is a significantly more usable and satisfactory tool.
  4. grober
    grober MB Master
    27,860
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  5. ghouluk
    ghouluk Active Member
    85
    May 2, 2011
    Car:
    clk320
    having used both petrol and electric on my hedges, i'd reccomend the petrol every time, yes its noisier, you have to have petrol around, and its a pain to start first time every year, but the difference is incredible - the first time you use a petrol hedgetrimmer after an electric one, its like a lightsabre on the hedges :)
  6. Mercy1
    Mercy1 Active Member
    620
    Dec 14, 2010
    Car:
    It's a car - just a car!
    Much depends on the type of hedge you are cutting. If it's privet or similar, electric will do a good job and electrics are generally lighter and pretty well maintenance free. If you have a tougher hedge like laurel then you might do better to go for the petroi which is undoubtedly better (will cut through like butter!). BUT it IS heavier and hard on the arms if you have quite a lot to do. And of course, you've got to mess around with petrol, and it'll never start just when you want to get on with the job!
    My personal recommendation for easy hedge cutting is the electric Viking Hel700k, which has a long shaft for high hedges but also makes light work of lower ones. It will cost you a bit more, but you will almost find hedge cutting a pleasure - well almost. lol.
  7. SPX
    SPX MB Club Veteran
    16,037
    Aug 29, 2010
    Yorkshire
    Car:
    That one
    Agree with the 'buy petrol' posts.
    All my garden tools are petrol, the electric ones I've had in the past lack that bit of power that you sometimes need.
    Also, there is no cord to accidentally cut through so electrocuting yourself is impossible.
  8. saorbust
    saorbust MB Enthusiast
    1,444
    Oct 24, 2003
    Car:
    CLS350CDI
    petrol every time - it's superb and easy to use.....plus doesn't matter so much if it gets wet...
  9. MicB
    MicB MB Enthusiast
    1,037
    Nov 2, 2010
    Beckley, Oxford
    Car:
    MB SL500 (R230) 2003, MB SLK320 (R170) 2001, Volvo V70 XC AWD 2001
    Yep, petrol every time. I have an electric one and it is a pain in the a***.
    In fact electric garden tools generally are to be avoided. I have an electric strimmer which is again a pain in the a***.
    The freedom of movement with petrol is everything.
    Mic
  10. OP
    OP
    wemorgan
    8,120
    Apr 5, 2008
    Car:
    A205 C220d
    Thanks everyone. Lots of useful information.
    Currently the hedges are about 3m high and 2m deep. I'm wondering whether to pay a tree surgeon for the initial cut-back to 2m high, then I can do the smaller more regular maintenance.
    For a 2m deep hedge I presume the electric trimmers with long extension handles are more suitable?
  11. Ted
    Ted MB Enthusiast
    5,758
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    SLC 250D AMG Line, Yamaha XVS 1100, Jeep Renegade
    If you can reach reasonably well with an extension cable, then my advice would be to get whatever is the best balanced.
    I was lured into buying a B&D electric with a long long cutting blade. I justified it as my hedge is up tosix feet high and around forty feet long - but the balance is so bad that my forearms ache after just a couple of minutes causing me to do a crap job (at least that's my excuse).
  12. E CLASS
    E CLASS Active Member
    413
    Oct 16, 2008
    There's nothing like holding a two stoke engine in your hands having fun revving the nuts off it and at the same time cutting your hedge!
  13. renault12ts
    renault12ts MB Club Veteran
    16,098
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    Yes, get someone else to reduce the height. Then get ELECTRIC. Firstly they are light. Secondly they are light. And last but not least they are light. If your hedge is a normal domestic hedge regularly trimmed, you will not need the heavy cutting abilities of the petrol. If you don't have too much hedge then electric is best.
    I just got a new one, with 60cm blade, from B&Q for £25. Unbeatable value. I cut our hedges 4 times a year.They are over 3m high so I use staging, and only use a long reach rechargeable to cut the furthest extremes of a hedge more than 2m wide at the top (blame the neighbours for that).
    Petrol is a boys toy (unless you really need it). Save your arms go electric.
    1 person likes this.
  14. jonnyboy
    jonnyboy MB Enthusiast
    2,562
    Nov 27, 2005
    Camberley, Surrey
    Car:
    1991 sl300-24 project,s124 280,w115 no interior, w108 project no engine
    What type of hedge is it? At 3m hgh x 2m deep sounds like a thickstem ie laurel or rhododendron. Makes a massive difference. Post the type then I will advise further.
  15. renault12ts
    16,098
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    Don't know about Will, but my hedge is privet.
  16. OP
    OP
    wemorgan
    8,120
    Apr 5, 2008
    Car:
    A205 C220d
    I'm not too sure of the names, so here's a photo. It's only 2m wide at the top of the new growth. I imagine it's 1-1.5m of more mature thicker growth, if that makes sense.
    [​IMG]
  17. moonloops
    moonloops MB Enthusiast
    5,294
    Oct 8, 2009
    :Location : Location
    Car:
    W204 C350 CDI AMG Sport
    Got to be a petrol strimmer, also make sure you get it detailed so you can sell it for more when you are done with it :D
  18. finisterre
    finisterre Active Member
    941
    Oct 6, 2010
    Buxton
    Car:
    Vito, Z4, 530i touring
    If they are anything like chainsaws I would choose electric.
    I have three professional and meaty petrol stihl chainsaws.
    They are such a pita to keep fettled I bought an aldi electric cheapie + honda generator.
  19. OP
    OP
    wemorgan
    8,120
    Apr 5, 2008
    Car:
    A205 C220d
    I see that Ryobi do this 'expand it' range. Looks like a nice idea. Though my experience of all-in-one power tools (not ryobi) was rather mixed.
    Ryobi Direct
    it's not clear to me what power until (electric/petrol) you buy to fit those attachments.
  20. ghouluk
    85
    May 2, 2011
    Car:
    clk320
    class :)
Share This Page
