Electric window
Discussion in 'Electronics' started by miketams, Jul 13, 2019.
  1. miketams
    miketams New Member
    4
    Jul 13, 2019
    BH25 5PW
    Car:
    Vito 109
    I have a problem with my passenger side window. The cog on the winder mechanism snapped so I replaced the wonder mechanism. Now when I open or close the window it doesn't auto stop and therefore starts to jump the cog. It also will not auto stop if you put downward pressure as it's winding up.
    Any answers?
  2. OneForTheRoad
    OneForTheRoad Hardcore MB Enthusiast
    2,327
    Apr 20, 2015
    uk.
    Car:
    2015 w204 c class amg sport premium +65 ford kuga 2.0 cdi zetec awd..
    My answer would be to have it fixed properly by a knowledgeable person.
  3. Wearsthefoxhat
    Wearsthefoxhat Active Member
    74
    Feb 10, 2019
    Sunny south coast
    Car:
    SL500
    Perhaps try resetting it so that it knows where it is. Hold the window button down, when the window is down for five seconds then do the up for five. See if that works.
  4. OP
    OP
    miketams
    miketams New Member
    4
    Jul 13, 2019
    BH25 5PW
    Car:
    Vito 109
  5. OP
    OP
    miketams
    miketams New Member
    4
    Jul 13, 2019
    BH25 5PW
    Car:
    Vito 109
    The problem is I can't hold the window button down because the motor will not cut out when it gets to the top or bottom and is going to strip the window gearing.
  6. Marku
    Marku Hardcore MB Enthusiast
    748
    Dec 18, 2012
    Car:
    Viano Ambiente 2.2CDI W639, S-Class 450SE W116
    As said it does need to know where it is. When refitting the gear the window must have been in the wrong position. It is not over running but simply trying to move to the fully open or closed position. I would disconnect the cables from the window and push it up to fully closed then reconnect the cables. I did this with mine when fitting a replacement cable and gear set. I have not had any trouble since.
  7. Stratman
    Stratman Hardcore MB Enthusiast
    4,653
    Jun 15, 2003
    Sunbury
    Car:
    W203 C200 CDI '04Estate
    When resetting the window it's important to use the 'first' switch position, ie. manual not auto. Press the switch to the first detent only and when the window gets to the end hold it there for five seconds. Repeat for the other direction.
    If that fails, see post 2.
    OneForTheRoad likes this.
  8. OP
    OP
    miketams
    miketams New Member
    4
    Jul 13, 2019
    BH25 5PW
    Car:
    Vito 109
    Makes sense, I'll give it a try.
Share This Page
