Mark.merc
- Oct 6, 2013
- Sl500
MY 2002 SL500 HAS DEVELOPED A STRANGE FAULT IN THE ELECTRICS.
SOMETIMES IT UNLOCKS SOMETIMES IT DOSENT IT RANDOMLY LEAVES THE WINDOWS SLIGHTLY OPEN AFTER LOCKING.
CLOCK SHOWS 0.00 BUT AFTER ABOUT 5 MINUTES RUNNING IT SETS ITS SELF TO CORRECT TIME.
PUSH BUTTON WONT OPERATE THEN IT DOES.
AND ALL SORTS OF OTHER ODD THINGS KEEP HAPPENING.
THE DIAL SHOWS ESP BUT AFTER TURNING THE WHEEL BACK AND FORTH IT WILL DISSAPEAR,IT WILL THEN SHOW CONSUMERS OFF LINE 1 MALFUNCTION.
I HAVE HAD A DIAGNOSTIC CHECK DONE THROUGH MERCEDES AND THEY SAY ALTHOUGH IT SHOWED SOME SMALL ELECTRIC UNDER VOLTAGE READINGS THE ALTERNATOR IS WORKING CORRECTLY AND BOTH BATTERIES ARE FINE AND ARE ONLY 2YEARS OLD ANYWAY.
THEY HAVE SUGGESTED IT MUST BE THE KEYS NOT TALKING TO THE KEY BARREL AND THAT REPLACING THAT MIGHT BE THE ANSWER? BUT AT £800+ “MY GUESS” IM NOT SURE I SHOULD TAKE THE RISK.
ANY IDEAS WOULD BE MUCH APPRECIATED
