I've had an issue since last Summer on my 2015 S205 where, increasingly, the EPB isn't disengaging (or at least the car thinks it hasn't disengaged)
You depress the brake (as normal) and move the gear stalk to go from P to D or R and a Red warning message appears on the screen 'Release parking brake' and the car will not move - take your foot off the accelerator and then depress the acclerator again and it moves. There's no pattern i.e. engine temp/outside temp/cold or hot start/duration of engine running make no differance and no fault codes are being logged either - but it is getting worse. The only small pattern I've noticed is that if it does it once, you can then get it to repeat over and over if you move between P and D/R.
The car has 3months MB used warranty left and has been in twice now for various software updates - I appreciate it's hard to fix witout a fault code but my concern is with it getting more frequent, at some point the EPB refuses to release and I'm stuck. Any ideas?
