'elegance' or 'avantgarde' badges on side of car
SilverSaloon
1994 W124 E300D Estate, 1985 R107 280SL
hi
on my clk i have an 'elegance' badge on the clip on plastic trim that runs the length of the car below the side indicator.....
are these stick-on or are there holes behind?
i am interested in taking them off you see...
The badges are stuck on with a bit of self adhesive therefore there are no holes. The same method is used/can be applied for debadging the rear bootlid i.e. using hair dryer to heat up the badge to soften it up before the dental floss or something similar.
When I foud out that there was an option at the factory to debadge the side trim badges it was too late to change my factory order by just one day.
Flash
They come off really easy, you will no doubt bend it, make sure you really want them off as they cost about £10 each !!!
yes stick on i removed mine from my clk,
