Hi all,
I have started working through a ML500 2002 model in silver this end.
Trying to bring it back to near showroom condition and slowly getting there.
Bought it last September.
I have done major repairs and servicing to date and thought I had got everything fixed under the bonnet when I went for a drive after replacing many parts.
Alternator -this was the first problem I had when i lost lights, at 18 years old I was fine with this. This was when I noticed the frayed throttle cable and also noticed it felt like there was a slight sticking point on the throttle pedal, hence I swapped them out.
Battery
washer bottle.
Throttle cable and pedal assembly, as old one was lose and cable was split and frayed under bonnet.
Removed and replaced both banks rocker cover gaskets, including the top small covers.
spark-plugs
leads
coil packs., everything original bosch, except the spark-plugs are Bosch double platinum instead of single.
I did the throttle cable first and after this no throttle, so thought okay, i've upset something, so worked on the other parts and finished.
I then bought an AUTEL maxiPRO MP808 to let me see if any faults or codes causing the throttle problem, and yes, one major problem.
P2001 N15/3 ETC-Electronic Transmission Control, ETC/EGS module is faulty.
Stored error and current error. I have included the readout from the scanner.
I do not have an expensive diagnostic scanner so am now stumped.
I have found the module, and not easy to find, and very hard to remove. (I have not removed it yet)
I have read you cannot simply remove this part and plug in a second hand one as they have to be a virgin unit and programmed to the vehicle vin number. I also read that the older ML M-Classes can have the modules swapped out, but hit and miss
If this is true, it means I have to go to the Mercedes dealership and wave good-bye to £1,000's of pounds to have this fixed as they will only fit and supply a new unit.
Or is there somewhere i could take my faulty unit to, to have them refurbish it if possible?
If it is calibrated and programmed to the vehicle, then refurbishing should at least turn it back to a virgin unit.
I also found this .PDF online, although it is left hand drive Mercedes model, so ETC module is NOT where this document says it is, as right hand drive, not left.
Battery
washer bottle.
spark-plugs
leads
