Ade B
Mrs B is stuck with Junior B around the corner from a garage in Croydon following a sudden coolant loss (I suspect the water pump which has had an intermittent squeak for a few months..)
She's put some more water in to try to get to the garage, but has stopped again due to lots of steam and concern about blowing a gasket...
I've told her to walk to the garage and see if they can pick the car up..,
My question is presumably the temperature guage reads the coolant temp, ie. no coolant = inaccurate reading... therefore it is it a mad idea to let the car cool a bit, stick more water in and then drive (literally round the block) to the garage if the temp reading is still in the acceptable range - which it is..?
Plan B is to call the insurance roadside recovery (which is likely to not be particularly rapid...)
TIA
Ade
TIA
Ade
