End Programs Question
Discussion in 'PC and I.T support/Advice posts' started by l5foye, Oct 13, 2008.
  1. l5foye
    l5foye Active Member
    815
    Jun 16, 2003
    N.Ireland
    Car:
    ML 300CDI
    I notice now everytime I go to switch off the pc, I get a message ' program not responding' ,above it, it says ' sprtcmd.exe'. When I search for this, 2 files come up. One is a Windows PF file and the other is a Dell help one. What is going wrong? I am on Windows XP. Thanks in anticipation.
  2. stevesey
    stevesey MB Enthusiast
    2,969
    Sep 3, 2007
    Bristol
    Car:
    Alfa 156 1.8TS
    It's a support tool internet connection issues, not really needed.
    Do Start->Run type msconfig then look at the startup tab, find it and uncheck it, this will stop it starting (so it won't be a problem shutting down).
    Normally my first step when setting up a new PC is to remove all this unnecessary stuff.
  3. Ian B Walker
    Ian B Walker MB Enthusiast
    7,672
    Jun 7, 2003
    Freckleton
    Car:
    300-24, saloon and coupe, E300 24 valve diesel estate
    That may be simple for someone who knows, but for numpties like me, what is the necessary stuff and what is the unnecessary stuff ?
  4. columb
    columb Active Member
    461
    May 11, 2008
    Exeter, Devon
    Car:
    W212
    Hardest question ever- and I'm not joking.
    It all depends. You could use HIJACKTHIS (tool) and past the log here so we can tell you what is not needed :)
    Cheers
    Chris
  5. Ian B Walker
    7,672
    Jun 7, 2003
    Freckleton
    Car:
    ok will see if I can do it. May not be tonight though :crazy:
  6. stevesey
    2,969
    Sep 3, 2007
    Bristol
    Car:
    Alfa 156 1.8TS
    Ditto, so hard that Chris got in well before me. ;)
  7. columb
    461
    May 11, 2008
    Exeter, Devon
    Car:
    W212
  8. OP
    OP
    l5foye
    815
    Jun 16, 2003
    N.Ireland
    Car:
    ML 300CDI
    Thanks Folks. I can check with you that it is ok to delete SPRTCMD.EXE which is in a Windows Prefetch folder ? I ran the Hijackthis program but am none the wiser.
Share This Page
