Paul P
- Sep 23, 2005
- Location
- Shopshire
- E320 CDI Estate 210 Elegance Facelift Yr 2000
Hi Guy's I Think we have a problem with the diesel shut off valve on the high pressure diesel pump which cut's off the fuel when you switch the engine off, sometimes the car will not start if left for a while it then starts, it will then run okay for two or three weeks with no problems then it happens again. I have been told that it could be the shut off valve sticking which is connected to the high pressure diesel pump, If I was to change this valve would I have any problems bleeding it when trying to restart the engine.
About 5000 miles ago I had a problem with the fuel pipes sucking in air, I have changed all the link line to the injectors and fuel pump etc. I had to take the radiator off to change the pipes on the fuel pump and it self bled after a few turns of the engine and it started okay would this be the same if I ordered a new cut off valve and changed that. I would appreciate any advice. Paul P
