220 are still cool. still a MercI have got a small amount of vibration on my 2011 E220 between 1500 and 2000 rpm in each gear. I can drive through it above 2000rpm but there is vibration if I coast back down the rev range to below 1500 rpm. The gearbox is operating normally with smooth gear changes.
I am thinking it could be engine mounts but there is no noticeable engine movement when I do the rev test with the box on neutral.
Just to add the gearbox fluids were changed about 25k miles ago with a full flush and the car has done 318k miles with all original parts still present.
I am guessing its getting a bit tired but passed the MOT yesterday with no issues.
Any thoughts ?
Sorry, just noticed after posting I have invaded the AMG lounge with a 220 diesel
Maybe a kind mod could move to general discussion, I hang my head in shame.
No , just buy an AMG badge off Ebay and slap it on. No one will ever knowI have got a small amount of vibration on my 2011 E220 between 1500 and 2000 rpm in each gear. I can drive through it above 2000rpm but there is vibration if I coast back down the rev range to below 1500 rpm. The gearbox is operating normally with smooth gear changes.
Any thoughts ?
Flattery will get you everywhere guys but about the vibration?
At 318k your engines mounts and transmission mount need changing buddy . Relatively cheap jobFlattery will get you everywhere guys but about the vibration?
I know what you mean , nobody likes unnecessary work . You either need a merc Indy to try and diagnose the slight vibration or start by spending the smaller amounts of money on the likely culprits .Amazingly all the suspension etc is original apart from one rear shock absorber bush which had slight movement at 80k ish miles and was replaced under warranty. Mercedes of that era were quite well made.
Just need to justify it to myself that the car is worth spending a few £00's on.
I had mine done at just under 100k. I thought it was fine (no discernible movement on the static rev test) but i drove a W212 courtesy car that had new mounts while mine was in for a service and it was clear mine needed doing! Transformed the car - much smoother and quieter and gear changes also seem a lot smoother.Flattery will get you everywhere guys but about the vibration?
As you have just recently done the gearbox ATF then that’s part of the likely problem areas done (unless it’s gearbox internals going wrong at that mileage )
Next up it’s got to be mounts and they are a part that needs doing ?
I think I have had 24 services, all bar the last two by the main dealer so it has been well looked after.I know what you mean , nobody likes unnecessary work . You either need a merc Indy to try and diagnose the slight vibration or start by spending the smaller amounts of money on the likely culprits .
You don’t get better than him buddy !Pretty close to Alex Crow who did the fluid change so he will be my first port of call to get a quote.
Its what most non AMG owners do anyways/..No , just buy an AMG badge off Ebay and slap it on. No one will ever know![]()
