Recently my c220d has developed a rattle/grind coming from the auxillary belt area, from 8 seconds in:
Any thoughts if this could just be a bad pulley bearing? There is some play and noise from one the idler pulleys when spinning by hand (video below), could be the cuase?
Is it ok to run the engine for a few seconds with the auxillary belt removed to see if the noise is still there?
Thanks in advance
Thanks in advance
