Engine Compartment Fuse Boxes
GlenQ
Derbyshire UK
2004 W220 S320 CDI
Hi
S500 W220
Before I get out the DMM does anyone know if either of the two fuse boxed located under the bonnet are ONLY LIVE when the ignition switch is turned on?
I am trying to find a fused supply for a set of DRL's that will only illuminate when the car is running.
I know that I will have to run this supply through a relay to turn off the DRL's when the headlights are on.
Diesel Benz
Europe
222.132 & 213.012 & 906.633
Is it really necessary to have the DLRs off when ignition is on but the engine is off? It would be easy to find a 15R fused output but the "engine running" signal might need to come from a CAN BUS (like the alternator on signal).
OP
OP
GlenQ
GlenQ
Derbyshire UK
2004 W220 S320 CDI
I only need the DLR's on when the ignition is on then take that feed through a relay that is open when the headlights are on so I need a fuse that is only live when the ignition is on.
Will taking a supply from the headlights (to energize a relay) throw up a fault with the headlight monitoring system?
