KLP 92
I have a 560 SEC with 102k on the clock.
I had the head rebuilt on it 6-12 months ago, 500 miles ago precisely due to a few running issues.
Well i've developed a misfire in the car (yet again!!) so decided to have the compression checked on it. The reading as as follows, from the front of the car to the back:
Left side:
205 PSI
205PSI
205PSI
205PSI
Right side:
205PSI
225PSI
235PSI
215PSI
The readings are in PSI and have been checked using 2 seperately gauges and performed when the car is hot and been driven all day.
Now i'm concerned about the right hand bank being so high in compression, especially the 235 and 225 reading. Is this a problem or not?
Also would this be a cause for the misfire or do i need to look elsewhere? So far the car has had a new:
Fuel distributor
Rotor Arm
Distributor cap
Ignition coil
EZL ignitin control module
CIS KE control relay
Spark plugs
ignition leads
Fuel injectors.
not sure what else it could be! I have been getting a ticking tappet noise form the right side of the engine, diagnosed as a tappet (even though a new one was installed 6 months ago).
Just curious to see what you chaps make of the compression ranges, as i took the car back to George Fraser who said that the figures were fine and wouldn't be giving me the running problems.
Any help/advice wopuld be greatly appreciated.
Left side:
205 PSI
205PSI
205PSI
205PSI
Right side:
205PSI
225PSI
235PSI
215PSI
Fuel distributor
Rotor Arm
Distributor cap
Ignition coil
Spark plugs
ignition leads
Fuel injectors.
