GordonMellor
I have a 2010 CLC Kompressor 1.8 and a message appears saying check oil on next fuel refill had oil change and filter but still happens after travelling for about 15 minutes , simply don’t know what to do
What procedure are you following when using the dipstick?Dip stick
It may have helped if you mentioned this in your first post.Thanks oil ok and filter
