jeremy156
I have been trying to track down the source of a resonating and rattly noise from the engine bay of my 2003 E320 CDI (inline 6 type) and have finally identified that it appears to be the plastic engine cover that's buzzing. I assume this cover is present to provide sound proofing, so it is somewhat ironic that it's now responsible for the noise that's annoying me, but I just had the car round the block with the covers removed and it lost that "something's loose" sound and came across as much more "together".
So.... my question is around quietening that cover down. Does anyone else find that theirs resonates when given a good thump? It appears that under the main cover, there's an inner plastic section which is glued in place and isn't entirely firm throughout, so I am thinking I should try to strengthen the bond.
My first thought is duct tape, however I don't know what sort of temperature resistance that stuff has - and with the engine running at 90 degrees internally, what sort of temperature the engine cover itself gets to.
Any suggestions or experiences would be welcomed.
Thanks,
Jeremy
Thanks,
Jeremy
