I used a chrome star from an old centre cap for the airbox cover:
It depends on the diameter of the recess on your engine cover, obviously - this one is 75mm.
If you still have the centre caps you've had on before EdOne were installed - the chrome star would come off easily, and normally is in much better shape than the surface of the cap - mine cleaned up nicely, as you can see above.
