Hi I have a SL350 R231
I took the car for MOT and the check engine light came on, plugged in icarsoft gave me an " Error P042812 Temperature Sensor 1 Catalytic Convertor (cylinder bank1) has a short circuit to positive. There is a short circuit to positive." and anther fault for the other sensor in bank 2
i have checked wiring loom connectors that are visible all look fine, does anybody have a diagram that shows the temperature sensors? if cheap enough I will replace them as pair
