Before I start thanks to anyone with any sort of advice as I'm really stuck as what to do. Car is a 56 plate e320cdi face-lift
Started the other morning went into town and noticed that the car was quite smokey but all seemed fine power was still there just smokies than usual anyways went back out later on and the car went into limp mode for no reason so pulled over turned engine off turned it back on no problems car come out of limp mode 5 minutes after this the engine management light come on! Now the car is underpowered at all times and under hard acceleration after about 60mph will go straight into limp mode.
The only thing I'm able to check myself was the fault codes through the torque pro app which came back as current faults P1408 which I believe is possibly something to do with the egr valve. And P2237 this is under current faults but also underneath that I get P2028 P2079 P2626
I really am at a loose end I don't know whether it's something to do with the egr valve or whether I should go and get the fault codes read by something better than an app on my phone something a bit more in depth. Like I say any but of information or advice would be greatly appreciated!
Cheers guys
Cheers guys
