BentleyBubble
Hi, My engine management light has been coming on over the last 18 months or so, but generally showing no fault. Sometimes it goes into limp mode with it on, sometimes not. It even went into limp mode with no EML on. Either way after about 10 restarts it generally re-sets itself and everything is fine for a few more months. I am wondering whether it could be to do with software as my clock has not re-set itself on the dash and is showing an incorrect time. (There is no way of re-setting it according to the manual it is an auto update, but the command system is correct and can be changed but the dash clock does not change with it - may be totally irrelevant), My SAT NAV also had a mental breakdown showing me to be miles from where I was, The EML also illuminated when a bulb went out (co-incidence?) and when a fuse went for the sunroof (co-incidence?). In general it drives wonderfully (when not in limp mode), it is almost 14 years old with 150,000 miles on the clock we have had it from new and I love it. We have spent thousands over the last two years on glow plugs etc and other things to keep it running, all done through a main dealership. However, we are likely to use our local garage, that has a good reputation and specialises in all things German. They put it on the fault finder and the code says that it could be the Turbo or the EGR Valve, but then why would the light go out if there was still a problem and drive fine. Gut feeling is it is an electronic glitch or software type issue. Thoughts/experience anyone?
