Hi Guys,
I have a problem with my car misfiring when in park or neutral only!
I took it to MB and they had it for a day but couldn't find the problem! They said that it misfires on cylinders 7,8 5,6,2 basically all of them except 1, but at different times.
If you turn the car off then on again the problem goes away for a couple of minutes then returns. Driving the car is fine with no loss of power or misfires!
Yesterday I took the car to an Indy that specializes with auto electrics, but he too couldn't work it out.
Plugs, coil packs, lamda sensors, compression check, CPS, injectors, fuel rail, vacuum and wires were all checked or swapped in the hope of a cure.
I'm now out of ideas as it seems no-one can find the problem!
Can anyone point out something which may have been missed out please?
