Parrot of Doom
I am about to order 2 new engine mounts for my E300TD. The belt tensioning device has yet again decided to pee its contents over the front of the engine (its the shocker that keeps going).
http://www.mercedesshop.com/shopforum/showthread.php?t=157401
I have the exact same symptoms as that fella. Spring broke a few months ago which I replaced, and the engine has eaten 3 shockers. Having never seen a 100% perfect belt tensioner in operation, I can only assume that the level of vibration seen on mine is anomolous, and needs attention.
The steering wheel on mine vibrates slightly, but not a lot. The car shakes very slightly when the engine is killed, but nothing major. At 176,000 miles I reckon its good preventative maintainance anyway.
Anyhow, has anybody done this job before? The advice I have currently is to remove the transmission pan, jack the engine 1/2 an inch or so on a big block of wood, whip out the old mounts with elbow grease and grunting (and bent/filed tools), and put the new ones in.
Does anybody have a 606 TD engine with a belt tensioner that doesn't vibrate like mine does? I'd thought it was normal, but apparently not.
