Engine never reaching 90C, high rev
Riva811
London
CL500 Blueefficiency
Hello, we have this W212 that has high revs and the temperature never goes beyond 75 - or at least thats what the gauge says. So I am wondering if they are interconnected issues and whether it could be a simple sensor about to go wrong issue? The car was recently diagnosed using SD4 with no issues discovered. I also run my MB V2.0 prior to SD4 and the ECU returns no error codes at all.
I would change the thermostat and the temp should be fixed, then see what it's like.
+1 for thermostat...usually the first and most obvious reason for running too cool, which will also upset the ECU, use more fuel etc.
If it still shows cool maybe check/change coolant temp. sensor
+1 on thermostat but before going further and more expensive get a thermometer and check actual temperature.
Thanks for the thoughts. Not sure how much a laser thermometer will cost, might as well go through a process of elimination. I suspect the thermostat is stuck wide open.
Sent from my J8110 using Tapatalk
Well if you're stationary you should see the temperature rise to somewhere near normal. It's only when you're moving that a stuck thermostat becomes apparent.
Another quick check is to feel at the big bore coolant pipe from top of engine to the radiator. If it is warm within minutes of starting a cold engine, the thermostat is stuck open/faulty.
Mb2 will tell you the actual temperature.
It will tell you what temperature the sensor is indicating. If the sensor is reading too low, so will the MB2. That said, though, it's more likely the thermostat is failing/has failed than that the sensor is faulty. A faulty thermostat will not generate a fault code; a faulty sensor might.
Dichtung (post #9) is right. The outlet hose to the radiator from the engine should remain cold or cool - there may be a slight leakthrough of heated coolant before the thermostat starts to open - until the thermostat starts to open, then heat up quite rapidly once coolant starts to flow through it. If it warms up steadily as the engine does so from a cold start, then the thermostat is definitely the culprit, not the sensor.
I noticed what you described with the gauge, it starts low, goes high and then drops. Don't really want to buy a laser thermometer for an one off hopefully
That suggests that the temperature sensor is OK, and the thermostat is working OK-ish from cold, but once it's opened as the engine warms up, it's staying open a little wider than it should once the coolant reaches operating temperature. I'd replace it and see what happens.
Google "replacing thermostat on (whatever year your car is) CL500"; you may find it's a very simple process. I had to do it on a 2008 W211 E350 petrol, and it was very easy indeed; not even any jubilee clips to replace - the hoses were all held in place with circlips. If you use an aftermarket 'stat, buy one made by an OE supplier like Febi; steer clear of names you've never heard of, like Cercoli.
This is for a W212 which is very simple, on my CL216 with M278 is a pain in the rear
