Went out in my today W210 E320 CDI no problem, entered dual carrageway floored it but it just gradually increased in speed (no kickdown) max 3000revs. There was no lights on in dash or malfunction, pulled over to investigate and noticed when reving engine from under bonnet the waste gate linkage wasnt moving, tried reving a few more times and it cleared noticed wastegate linkage moving and you could hear it boost. Got to destination with no more problems after 30 mins i departed for home yep problem was back car changed up gears ok but no boost or kickdown and on dual carrageway it would cruise ok at speed but no fast acceleration. got back home and checked under bonnet same problem as before got it to clear but it came back again still no fault showing or light on in dash. Disconnected Maf sensor and started car didnt make any difference still no light or fault and car wouldnt rev past 3000 revs cleaned it all up and put back on car worked fine car went great but when i went back to car 20 mins problem was back. Has anyone had the same problem and am i right in thinking it is the maf sensor.
