Engine oil? E300TD W210 606
Discussion in 'Engine' started by AANDYY, Oct 1, 2008.
  1. AANDYY
    AANDYY Hardcore MB Enthusiast
    960
    Sep 2, 2008
    Blackpool
    Car:
    E300DT-W210-1997-Elegance-Azurite Metalic Blue. (Don't mention the rust, LOL) Running on WVO. 65k m
    Done a search but can't find anything.
    What oil should I use?
    Handbook is no help:(
    It's not to be done for about 6K.
  2. SilverSaloon
    SilverSaloon MB Club Veteran
    7,759
    Mar 16, 2004
    Car:
    1994 W124 E300D Estate, 1985 R107 280SL
    10w40 Semi-synth is what i use in my 606
  3. OP
    OP
    AANDYY
    960
    Sep 2, 2008
    Blackpool
    Car:
    I was thinking of that myself:)
    Just need some more info from peeps please:rolleyes:
  4. Timster
    Timster Hardcore MB Enthusiast
    556
    Jun 24, 2008
    Scottish Borders
    Car:
    Currently Merc' Less.
  5. OP
    OP
    AANDYY
    960
    Sep 2, 2008
    Blackpool
    Car:
    Yer Iknow that stuff and I'm a member of that forum, what I understand is that if you do regular oil changes, say 4-6k wich I normally do anyway, that should be OK without that oil.
  6. SilverSaloon
    7,759
    Mar 16, 2004
    Car:
    yes i'm going to start using Halfords own brand. apparently its good anyway, but if you are changing more often anyway then i reckon its perfectly fine.
    Plus at the moment u get a good set of screwdrivers free. I have 3 sets already!!!!!
  7. OP
    OP
    AANDYY
    960
    Sep 2, 2008
    Blackpool
    Car:
    I agree. £23 for 5Ltrs.
    Ours takes 7Ltrs:eek:
  8. wab_w202
    wab_w202 New Member
    3
    May 29, 2008
    Car:
    W202 C240 sport
    Try Fuchs engine oil, Fuchs is apparently factory fill engine oil for most german marks.
  9. spock500
    spock500 Hardcore MB Enthusiast
    727
    Apr 1, 2008
    Milton Keynes
    Car:
    S124
    Best place I found for oil was Asda/Wallmart - they had a special on Havoline mineral 15/40, 5ltrs for £7.50, also had their own brand which had the equivalent AP rating for £6.50
  10. bolide
    bolide Hardcore MB Enthusiast
    3,726
    Oct 8, 2005
    Brighton
    Car:
    BMW E39 525 Diesel Touring
    Bear in mind that the 606 is a relatively low-revving, unstressed engine in a low state of tune. It'll run on any old oil
    But it has hydraulic tappets, two cams, 24 valves and a duplex chain and they all need lubricating. It also dumps lots of soot into the oil
    So I'd use a good oil (in that it meets MB minimum specs) with enough detergents, etc to keep the engine internals clean. I'd change it on schedule (9k) or use a 6k interval if you're really keen. And I'd use an MB filter
    But I wouldn't put Mobil 1 in it - I'd spend the money on new bushes & engine mounts where it'll make a difference
    Nick Froome
    www.w124.co.uk
  11. Number_Cruncher
    Number_Cruncher Hardcore MB Enthusiast
    987
    Jan 14, 2008
    Midlands
    Car:
    1995 E300D
    >>Handbook is no help
    Really?
    What does it say?
  12. OP
    OP
    AANDYY
    960
    Sep 2, 2008
    Blackpool
    Car:
    :eek: I should have expanded that, I don't have the maintenance booklet:p
  13. Smiley
    Smiley Hardcore MB Enthusiast
    2,060
    Jun 29, 2008
  14. Number_Cruncher
    987
    Jan 14, 2008
    Midlands
    Car:
    1995 E300D
    I ask about what the handbook says, because I run a W124 with a naturally aspirated OM606.
    I'm sure that my service regime is exceeding the requirements for oil standard, but, I would be interested in what MB say in their handook for the OM606 in the W210. Perhaps a W210 owning member of the forum would be kind enough to post the oil quality and oil change frequency advice written therein.
  15. spock500
    727
    Apr 1, 2008
    Milton Keynes
    Car:
    S124
    Try this, I used it for the tranny fluid;
    http://www.datateck.com.au/lube/caltx_au/buttons/default.asp?section=1
Share This Page
