I normally change my engine oil via the dipstick using the pump method.
This has worked fine for the last year.
I would like to do an engine oil flush but am worried that the engine flush will dislodge a lot of gunk that will block the pump.
Is this likely. I do not have the facilities to do a sump drain.
Cheers
Cheers
