Sp!ke
Administrator
Surely once you've removed the dirty fuel you could simply filter it (thinking paper coffee filter or similar) and put it back in the tank afterwards. This would be a lot easier than finding a way to dispose of it no?
FOUND THIS IN THE REAL OEM ARCHIVE SECTION.
TANK DIAGRAM
RealOEM.com * BMW E28 M535i FUEL TANK/FUEL FEED
FUEL FEED
RealOEM.com * Diagram Selection
Looking back at that fuel rail diagram in post #12 under fuel cooling 3rd diagram down that item no 1 64531386484 Looks to be some form of heat exchanger??? might be worth a look for internal leakage /blockage - you could short it out temporarily to test??
