Robcob
Hi guys,
my names rob i have a 2009 mercedes ml 320 cdi with full amg kit and a 2015 mercedes vito 113cdi it's the vito that's been the problem with a faulty injector thats caused a bent conrod low compression and a chunk taken out of the bottom of the liner so i have taken the engine out stripped it all down had a new liner fitted along with conrod and piston and just putting it all back together i have set piston number
1 to tdc with the crank pulley and am just waiting for a new chain kit to arrive to set the cams up ,the chain drives the high pressure diesel pump now doe's this need timing or is it just to pressure the rail up and the rest is done by the ecu.
cheers rob
cheers rob
