Myself and another indie has had a problem with their chain kits, both had stretched chains after a few 000 miles?? . Maybe a bad batch but will only fit an oe chain now.Avoid the eBay kits for timing gear & chain. m271.com are recommended by a few on here for their kits and they are based in Camberley
MB & other brands had policy of buying Made in China at one time.Myself and another indie has had a problem with their chain kits, both had stretched chains after a few 000 miles?? . Maybe a bad batch but will only fit an oe chain now.
Yeah it is steep, what would be a good price to remove the head and get assessed?£800 just to remove the head is very steep id hate to work that out at an hourly rate 2hrs max
If they charge £60 ph say 3hrs that gives them about an hour to inspect which could be done in 15 mins real timeYeah it is steep, what would be a good price to remove the head and get assessed?
SMS do you do recovery's?On its own 2x £70 plus vat if just a strip and assess but we would not charge separately if doing whole job. Gives you a guide.
Unfortunately not, we sub out to small local guy, knights recovery 07786 811010 but you could try local to where you car is.SMS do you do recovery's?
Hey Alex, where are you guys located?Agreed, no point in fitting another engine, they all have the same flaw and the donor engine will have the same fault at some point, unless "rebuilt"
Head off, chain replace, valves replaced, new gears/tensioner - Last one we did was approx. £1700 all in with skim and service.
