Ruhul9127
I was wondering if someone could give me some much needed advice.
On March 31st 2020 (just before lock down) i took my Mercedes GLC for a Service A at an official Mercedes garage for a service at 67k miles. Prior to this service my car was as smooth as butter.
Part of the service A Mercedes carried out involved a brake fluid change, engine oil change, filter change and ad-blue top up as well as an emission software update.
After this service my GLC now judders for at low speeds just before you come to a stop. I have taken the vehicle back three times to Mercedes - they carried out a gearbox and torque convertor adaptation and changed the gearbox oil. This seem to still not solve the problem. Mercedes representatives carried out all checks and no error codes show up.
The judder only occurs just before the vehicle comes to a stop. It always occurs regardless of whether the vehicle is hot or cold. If i use the manual paddle shift the judder still occurs.
I also took the vehicle to an independent garage and had the transmission mounts changed and that still hasn't solved the problem. I've been told it may be the Torque Convertor but no error code shows up when a diagnostics is carried out. somebody please help!
The sensation of the shudder you get is the feeling when you ride the clutch on a manual car - the whole vehicle shakes. This only occurs on gear 2.
Can anyone advice? I feel really down by the situation and it has caused me a lot of stress.
Ruhul
Ruhul
