Engine warning light
Discussion in 'Engine' started by Markjames, Dec 6, 2017.
  1. Markjames
    Markjames Active Member
    704
    Sep 14, 2012
    Ashford, Kent
    Car:
    mercedes e220 coupe
    I have a 2015 e220d coupe, blue efficiency model. Pulled onto motorway this morning and Amber engine warning light came on. Didn't at first seem to be any change in performance but noticed after a while gearbox will not kick down. Also option for maual gearbox mode has disappeared.
    When off motorway noticed it is now reluctant to change up gear, holding onto about 3000 rpm before changing up even in eco mode.
    It's booked into Mercedes on Monday as that's earliest they can get it in. They have said it is safe to carry on using it.
    Any One got any ideas of what could be causing it and also opinions on whether to keep using it.
  2. Mustang99
    Mustang99 Member
    33
    Nov 6, 2017
    Hemel hampstead
    Car:
    Mustang
    What is the exactly warning light you got?
  3. OP
    OP
    Markjames
    704
    Sep 14, 2012
    Ashford, Kent
    Car:
    mercedes e220 coupe
    Not from my car but this is the light
  4. DSM10000
    DSM10000 MB Enthusiast
    6,896
    Jul 12, 2011
    Near Salisbury
    Car:
    E32O CDi Sport, MX5 1.8 Sport, RR 4.2 SC
    Stop guessing and just have someone competent read the fault code(s), it will be far quicker and cheaper to resolve this way.
  5. Markssl
    Markssl Active Member
    493
    Jul 23, 2014
    Limp mode! Could be 100’s of things. But it’ll all be ok!!!
  6. Mustang99
    Mustang99 Member
    33
    Nov 6, 2017
    Hemel hampstead
    Car:
    Mustang
    Well, I don't think you can figure it out here...You should go check it even you didn't already did it? If you did let us know what happened.
  7. toteimerced
    toteimerced Active Member
    108
    Apr 2, 2017
    Car:
    C 220 CDI sport edition
    I would hazard a guess at a boost leak, but could be anything, as said, get the codes read and let us know.
Share This Page
