Engine Warning light
Southportchap
Northwest
R231 SL 350 Mercedes
Morning.....
Engine light came on. A pal has a diagnostic plug in jobbie and the following was shown:
P2214 NOx Sensor Circuit Range / Performance Bank 2
Should I be concerned?
Nox sensor on exhaust system has failed / failing, your car will still run ok just not as efficiently. replacement is relatively easy depending on access. If your not handy on the tools a good indy will do the job, not expensive to do.
Thanks for that.
I took car to Indy MB they found that
I had been using cheap fuel which I hadn’t,
My car is supposed to take 95 but I’d been using superior 97 minimum so all a bit strange.
cheers.
