Engine water temperature
Tgr747
Uk
C43
I have a 2019 c43 estate.can anyone tell me what the mbenz figure is of when the cooling fans should should cut in.if not what temperature does yours cut in,thanks
I've owned a few mercs now and can't ever remember the fan kicking in. All dirty diesels though.
Full yield is 100degreesC.
Most fans tick over at 80-90 degrees. The fan is also used for the AC too so its not necessarily engine temp dependent.
mine appears to be cutting in at 92 degrees.the problem is its just started doing this the last few weeks.at the moment we have very cold weather.it never did it in the summer or autumn when the ambient temp was higher.what i am afraid off is when the weather warms up the fans might be running nearly all the time leading to them to break down prematurely.
Cutting in so you can hear it? Is the fan going fast?
if i stop at traffic,or park the car up and switch off engine the fan cuts in within about 15 secs,it runs at the high speed for a few minutes,then a few minutes at the slower speed.
You could have a faulty AC pressure sensor. Id get it plugged in to check fault codes and the AC pressure sensor actual value just to be sure.
Mercs typically run (have thermostat operation set) at 87-90 degrees C depending on model/age. Slow speed fan at 92 degrees would be normal.
If the fan is kicking in at this time of the year whilst very cold outside, you are either constantly interrupting diesel DPF regen (that doesn't apply in your C43 case) or you have a fault somewhere.
After fault code checking, the best way to look at this is with diagnostics looking at live data whilst the car is running up to temperature. Looking for wayward temperature readings or the AC system for faults or unusual reading as BlackC55 suggests.
Most likely culprits are AC temp/pressure sensors. Water temperature sensors. Thermostat.
I have known fan control circuitry to become faulty on much older cars after eventual water ingress, but this gave erratic fan behaviour and the water of course didn't get over temp, because the thermostat was doing it's job properly.
Have you checked that the coolant level isint really low as that can trigger a fan to come on
yes,coolant level fine,its never used a drop.
