NotConvinced
- Oct 14, 2015
- C250 Coupe 2011 W204
I need the advice of you experts on here! My car is 2011 C-Class coupe C250 2.2 CDI. OM651 engine.
Here's what's happened.
I started the car one morning and the idle was very erratic, before eventually the engine stalled. Didn't get off the drive. 30 mins later it started and ran fine all day. Now, the exact same thing happened about 10 months ago but it's been fine for the last 10 months, all through winter up until now!
I took it to mercedes to put it on their machine and they came back with these error codes.( P200A75 was the error code when it happened 10 months ago also)
P200A75 "The charge movement flap (cylinder bank 1) has a malfunction. The emergency position was not reached".
P040100 "The flow in the exhaust gas re circulation (cylinder bank 1) is too low."
I've been quoted £700 just to open up the engine and look at the intake manifold and flaps. That's before parts and assuming they'll find anything wrong.
I was wondering if you guys have any other advice or things to try before opening up my wallet.
Thanks very much!
Thanks very much!
