Am documenting below the sequence as it happened:
1. Turn key to ignition on, no heater glow plug indicator on and starter does not turn.
2. Switched off and removed key to try again, now the enigne cooling fan remains on even after the key is removed and there is a hyper clicking sound coming from a black unit located on the right side (as you stand in front of the car looking towards the engine) near the firewall.
3. Disconnected the battery cause there was no way to stop the fan and the clicking!!!
4. Opened the clicking black unit cover to reveal a host of wiring and connectors and fuses.
5. The 4th (10A) fuse if removed results in the heater working again, the clicking stops and the enigne fan turns off. The engine turns over and starts, but now, the fan runs at full speed with the ignition on and the display says 2 malfunctions 1. Elec. Power Cont. Fault & 2. Engine fan... fault visit workshop (obviously the fuse removed sets of this fault.)
Any suggestions?
Any suggestions?
