philepo said:MB dealer has quoted £245 to change, plus Star time. He also said he has never seen one fail, so is not convinced it is that...
He also said that the ATF should be changed every 31000 miles (expensive!). Total confused... I thought it was either sealed for life (mad) or once at 37000 m (not quite as mad)????
Service A quote was 240 quid for basically an oil change! does that sound right?
cheers, p
philepo said:Spoke to another MB dealer: hese do not need to have the ATF changed becuase the clutch plates are harder wearing than the later boxes. He id then go on to say that if it was his car he would have it done.. cost = £305, is that ok???? And he also said it is most likely thermostat...
