Error Messages P0015 and P0025
clsking00
CLS
Guys I am having this error on my merc ... What is this code relating to ...
Any thoughts??
Jeff it lists the same information as above ...
Just wanted to find what does this mean??
Is it the sensor problem?
I googled but so many varied responses coming up ..
bit further down there's dtc search ... gives a bit more info
Camshaft issue?
P0015 Continuous camshaft adjustment ( RIGHT ): Incorrect position of the exhaust camshaft (P0015)
P0025 Continuous camshaft adjustment ( LEFT ): Incorrect position of the exhaust camshaft (P0025)
But people say that it can be due to sensor issue as well?
Or is it camshaft issue?
What are the signs by which I can tell whether its really an issue or not ...
Cause by the looks of it , looking a big engine job if true
Secondly, Important part is:
On the codes its list the same as problem B and problem A .. Like P0013 is the same problem but A ..
Is A more serious or B??
How serious is this issue? And what are the after effects
Really?
I thought 15 is right and 25 is left??
Garage said that its the magnet that needs to be replaced.....
