ESP,ABS display lite up 06 cls500!
djbcls500
USA
2006 CLS500
First hello,i'm in USA,lets start with lights in display esp,abs,convience off, visit brake workshop . Red light on esp abs. locked trans(after i cut off. But i opened shifter boot and put in neutral) car started up fine. Turned wheel L2R several times . Car moved forward but not reverse,steering felt draging.Started to move car would only go -30mph.
I had lots of codes : mileage 197965
6230
6210
54f0
4a42
c227b
c225c
c26ec
c2234
cleared codes then this showed up Used icarsoft mb 2 for codes
c25d4
c26ec
then i started car later that day and cheked driveability, car went into drie and reverse this time reverse worked. drove down street but car stayed in low gears.Checked codes again
Codes:
p0600 current and pending
p2000 eng select module
p2037-000
c25d4
c26ec
54f0
4a42
9012 sam door
9026
9055 bat con mod
9050 consumer shutoff stage 2
9051 consumer shutoff stage 1
9103 instrument cluster EGS fault CAN communication with control trans control or ASG auto manual trans AS tronic
wow what i'm facing
and sbc hasn't been replaced...can i get some help here
Make sure the main battery is good. This cars are very sensitive if the battery is weak
