TheCaptain
- Dec 14, 2016
First PLEASE read this. it seems long because i have put all the information anyone should need so that we dont have to go back and forth too many times:
ESP problem Need to Calibrate with Star 4?:
Is anyone VERY familiar with setting up Steering Angle Sensors?
I have a 203.046 (C180 2002) which developed an SRS problem. After a lot of trial and error I finally got my MB Star 4 with external HD working. The faults I got were for Driver Airbag Squib 1 and 2 having too high resistance. I removed the squib (which I note some people refer to as the steering angle sensor – but as far as I can tell, it is not).
I gave the part number to Merc and they said they have two on backorder since September. I found the exact one on eBay so I bought and installed it. I cured the SRS problem but acquired another problem by accident and now need to know exactly how to recalibrate the Steering angle Sensor.
It was when I went to push the new squib into the centre disk (which I believe is the steering angle sensor) I noticed there were a few pieces of plastic lurking in the centre. I assume thes broke off the original squib or possibly the steering angle sensor. I do not think they are important as long as the squib connects solidly with the remaining plastic available in the centre. However I thought better to get them out. In doing so I turned the centre rotating plastic several times before I got all the pieces out.
Then trying to figure out what position to put the rotating centre piece in to be correct for the squib to plug on, there seemed to be only one position where the two main pieces on the squib centre line up with the gaps on the steering angle sensor so I matched them.
Before putting it all back on I noticed the centre of the SAS seemed to turn 5 turns in one direction and 6 in the other to get back to where it was (looking through a small hole in the housing some little triangle markers pas by each complete turn but one of them is a different colour to the others) so I figured that going all the way until the different marker appears again was a complete ‘lock to lock’ turn. I therefore went 2 ½ turns from it one way and that appeared to be half way through the complete cycle (even though that does not quite add up :-/ ) and putting it there also lined up the two holes with the main plastic lugs on the squib so I connected and put it all back together.
The red SRS successfully erased so I knew I had replaced the correct part and that the eBay item was working. However now I have ESP visit workshop and this is an MOT failure now. It will not erase and I got error codes B1000 The Control Unit is Faulty current and stored and B1353 stored. I followed the procedure as far as I am aware (i.e. start engine, turn full lock both ways etc) and tried to erase the codes. The stored one went but the B1000 stayed.
I checked the ‘Actual Values’ and got:
142 N49 Steering Angle Sensor Not Initialised
143 N49 Steering Angle Sensor √/-F-
141 Steering Direction Right
140 Steering Angle 1023.5
When I clicked on the 143 value to try to change it from –F- it I got:
‘This Actual Value behaves in the same way as fault code 1334: If the actual value indicates –F- , fault code 1334 exists as current fault’
Questions:
1 do I need to take the steering wheel off and turn the squib/SAS a few times?
2 If not and I just need to calibrate the steering angle sensor, how do I do it with MB Star C4 DAS
3 Any other steps needed to fix this problem
Help very much appreciated as this is urgent and I am doing it now. Thank you in advance.
Questions:
