ETS Problem
mrML320
Banned
Byfleet, Surrey
ML320
Was camping the other day in E.Sussex in my 2001 pre faclift ML320 and the ETS,ABS,Brake Disc and Handbrake came on plus a warning sound, it kept doing this after turning off the ignition and back on again a few time, also whilst driving the speedo was not registering:cool: . I had driven through a field so could it just be dirt on the speedo/abs sensors? it went away after a while.:o Ta in advance
Probably mositure in the system causing your problem. Maybe a instrument cluster problem also.
A fault code read will probably tell you the cause.
