ItalianTuneUp
http://m.bbc.co.uk/news/science-environment-26257703
Seems like there could be trouble ahead for diesel car drivers?
Diesel exhaust gases are nastier than petrol. What a shocker! It's pretty obvious if you sit behind a bus in traffic, which is why I never do it with an open window.
Not sure if this is correct, but I'm told an italian tune-up clears the DPF...So I wonder if UK levels are 'too high' due to things like dpf removal?
Did I hear right that the dpf gets clogged up, and then it needs cleaning out? What other symptoms does a blocked dpf cause? Sorry if these are newbie questions.
And is cleaning dpf expensive?
Completely? How often does one need to give the motor an Italian tune up?
I thought I saw DPF cleaning services available from some companies, so if a good old-fashioned boot down the road clears the DPF out, why are these companies in demand, if they are that is?
I can't speak for other makes but my wife's Saab showed a warning light for dpf and the solution, as quoted in the handbook, was to drive for minimum 15 mins at 70mph. We did that and the dpf cleared.
It only clogs when doing short trips at low speed over a long period of time, apparently.
