dickchailey
If you are running or installing EWAnet do not allow JAVA to update to version 1.6. I found I could not run ASTRA from the server and after a lot of time I found it necessary to remove all the JAVA runtime versions, reboot and install the version on the DVD. Then turn updates off on the JAVA console. Seems EWAnet does not like the updated JAVA software.
(Not sure if this is the correct place to post this, apologies if wrong.)
