se97mlm
Well I have just returned from a visit to Steve (R2d2's friend), to have my autobox oil and polybelt tensioner changed
I can only sing this guy's praises. Excellent job done in no time at all and very cheapy indeed. He is very experienced and went over the car with a fine toothed comb to check for any potential problems. He cured the mysterious rattle at various engine speeds by replacing bolts and washers on the cat heat shield and solved the wind noise issue from my rear window with a little tweaking. Just need new ball joints up front and all will be well.
Car runs like a fream now with it's new gearbox oil, changes smoothly and swiftly, and i no longer get propelled through the windscreen going from 4th to 3rd!
Please use Steve if you live in the Kent area, he really is a legend, and is worth supporting. pm me for his mobile number.
