exhaust noise?
esox
When i start my 230K from cold the exhaust sounds like it could be blowing .possibly from the ex. manifold-its not overly loud but if even the wife has noticed it then theres something there right?However, after about a minute (by the time ive closed the gates) its quitened down,anybody else with a 230k noticed this?
white190
Ipswich UK
190E 2.0 1993 Auto
often happens with small exhaust leeks on many cars
as the exhaust warms up and expands it seals the hole...
this is often an exhuast manifold gasget as the exhuast maniflod warms up much quicker then the cyclinder head and so expands quicker.
A cracked manifold will also do that ......but 99% of the time its something simple like a gasget or sealing ring.
get it checked out tho as it wont get better on its own.
fuzzer
Glasgow
F25 X3 20d SE
Get it back into the dealer and kick up hell as it should be still under warranty. An exhaust should last longer than 2 years !!
JCrosby1000
CLK200K Coupe (W208)
Ive got the exact same problem with the 200K flavour, what did you do to resolve the problem in the end??
silverclk230
midlands
clk 230 cabriolet
I don`t think its anything to worry about as my 230K is just the same.
The cars been on the ramps at a local s/h car dealers and we couldnt find a leak (12 months ago - its got no worse since) and we concluded then it`s a quirk of the Kompressor.
A colleagues SLK 230K sounds just the same.
Cars in for a B sevice at Andy Gayle next week - I`ll ask Andy about it if you like.
JCrosby1000
Late update!!
I took mine to the local dealership as well, basically said the same thing, just a quirk with the Kompressor!
Wonder if theres anything that can dampen the noise.
marcos
Hertfordshire
C43 estate
My dads old SLK used to do this so I think it is a charateristic of the Kompressor engine. Did it for years without getting any worse.
Flash
UK
Mercs
my C200K W203 used to do that as well within the first couple od montsh of ownership straight from factory - but after a while it quitened down - it was the kompressor....
