Exhaust tips C207
Carrotchomper
Deepest darkest Zummerset
C207 E350 CDI coupe
Whilst fettling my lovely car the other day, I noticed these. Predictably enough they wouldn’t budge, I definitely don’t think the old owner was the obsessive detailing type!
Before I break anything, are these exhaust tips designed to slide out a bit for extra bling?!
I could only see this Allen bolt, is there anything else that needs to be loosened first?
ta :)
That is the only bolt you need to loosen, then slide to the end, did the same with my C207, it's surprising how much better it looks. :) 👍
Take them off while your at it, and give um a good polish, they come up great. :cool:
How did you go about painting the callipers?
Halfords engine paint,
(Not caliper paint) it's thicker, and only needs two coats, I found the caliper paint like pi$$ you'll need at least four coats. :) 👍 And it is just sh1te that make them hard to remove, you have to give them a really good wiggle. :rolleyes::) Before you put them back give the exhaust a rub with sand paper, makes it a lot easier to put back on, and put a bit of grease on the nut.
Great stuff cheers, that’s the next dry day off‘s activity then!
