Experts eh!
developer
Volvo V90 D5 AWD
I alwasy want the expert to be an expert.
It's their expertise I'm interested in and I SO want them to tell me something beneficial to me and my particular problem - especially when I'm stuck :confused:
Check out the pertinent bits in RED below from a pay as you go expert mechanic website ............
Customer Question
I have a Brabus D6 (III) for a CLS 320cdi secondhand with out fitting instructions, the important wiring harness has 5 plugs, plus the main plug to the unit, could you explain how to fit this or point me in the right direction to get information to fit this.
Best regards Gary​
Submitted: 471 days and 17 hours ago.
Category: UK Car
Value: £11
Status: CLOSED
Optional Information
Year: 2005
Make: Mercedes-Benz
Model: CLS 320cdi
Engine: 3000
Posted by Stan 469 days and 16 hours ago.
Expert's Answer
Hello,​
1 connector goes to the 1st injector,
2- to boost pressure
3- to commonrail pressure sensor.
4- goes to fusebox.
Good Mercedes mechanic will know exactly which plug goes to which sensor if something is unclear. It is almost impossible to mix the plugs up. The plugs are come in between the element and wiring harness.
Best Regards,
Stan
469 days and 11 hours ago.
Customer Reply
Hi Stan, Thanks for your quick response, but l had the unit fitted at weekend. Just to let you no the harness has 5 plugs .
2 plugs connect to injector 1 &4​
1 plug connect to the quantity control valve
1 plug connect to the commom rail pressure sensor​
1 plug connect to the boost pressure sensor
Thanks anyway Gary​
Chrishazle
Nr Ashford, Kent
2008 S204 C220CDI Elegance Estate Auto, 2008 R171 facelift SLK280 Auto.
One definition of an expert :
Ex = has been
Spurt = Drip under pressure
MicB
Beckley, Oxford
MB SL500 (R230) 2003, MB SLK320 (R170) 2001, Volvo V70 XC AWD 2001
Never admit to being an expert.......specialist yes, expert no.
Mic
Doodle
Echo Beach
R129, Leon Cupra 290, KTM 1290SAR
He's given the instructions for the D6(II) box instead...
grober
MB Master
Perth, Scotland
W204 ESTATE
Should have gone to specsaver----------------BRABUS in Germany [ they will speak English and everything!] The old adage "why speak to the monkey when you ask the organ grinder " comes to mind.;)
