External Temperature displaying 58 deg C !!!
jasohal
London
S320 E500 E55
Help !!!
I have a E320 Coupe 1995 model.
On the LCD dash display below the speedo the gauge is suggesting it is 58 deg C.
Is this a simple case of faulty external temp sensor ?? where is this unit is it easy to replace ?? and any idea on price part no etc ??
Any ideas much appreciated.
Brian WH
East Midlands
JAGUAR XF 3.0D Premium Luxury
jasohal said:
Help !!!
Could be faulty could just be dirty. They are usually at the front of the car under the grill, or the skirt area. Try and find it and see if it is disconnected or dirty etc. Its cylindrical clipped somewhere.and will have a wire out the back.
OP
OP
jasohal
jasohal
London
S320 E500 E55
Cheers...
I will look for it and let you know how I got on....
remus98
Did you find it? My temp shows 86c, I can see the sensor but can't get to the back to see if it is connected. C220CDi
Brian WH
East Midlands
Sounds as if yours has failed and wants renewing mate.:eek:
dubtaxi
Dublin
W210 Facelift E220 CDI, A140,
Mine(W210 E220 CDI) is also showing a constant 58 deg. I thought I had moved to Mars. anyone Know how to fix?
OP
OP
jasohal
jasohal
London
S320 E500 E55
Simple - get it replaced.
Should be around £30 -40 from stealers..
I did and it fixed mine !!
fnkhan68
London
1993 Mercedes 320e and 2000 BMW E39 523i
i too have a similar problem. on starting up my car the display shows 38c for about 3 seconds and then goes completly blank. any ideas?
Ian B Walker
Freckleton
300-24, saloon and coupe, E300 24 valve diesel estate
On my E220 the temp display reads 10 degrees low all the time, the engine temp reads 50 - 60 and the speedo is 15mph out. I think its all to do with the resistor pack behind the instument cluster. If it is then i will let everyone know. failing that its new cluster time = £'s :crazy:
Brian WH
East Midlands
Sounds logical to me.;)
