Hi All,
I have a 2013 C220 (70K miles) that has cost me a fortune since Christmas with various different repairs. Recently it overheated, went into limp mode, I had a tow to the garage, and ended up replacing the thermostat and a couple of sensors - not a huge problem as this was less than £500.
A few weeks later though I noticed the header tank full of oil, so took it back in. They diagnosed a failed oil cooler, and replaced it, along with a new water pump, oil filter housing gasket, and fuel filter housing. It was flushed through a few times to try and get all the oil out, and only a tiny amount remains in the header tank - too small an amount to syringe out. I've kept an eye on the dipstick and can't see any mayonaissy stuff on it, so am not too worried yet about the head gasket.
I'm sure that the oil cooler failed due to overheating when the thermostat wasn't working properly - but my worry now is whether this is going to be an ongoing issue, and should I just get rid of the car before this problem reappears, and something else was damaged when it overheated?
Obviously nobody has a crystal ball, but would the general opinion be to get rid and buy something cheaper, or to keep an eye on the header tank and dipstick and hope for the best?
The other thing I've noticed is the temperature gauge coming down by about 10 degrees when I come off the motorway. Is this normal?
Many thanks for any advice or opinions.
