Fan running after engine turned off 2019 cclass
alan a
spalding
1986 300SL and 2015 c class estate
Mercedes 2019 c class fan has just started to continue to run after car has been turned of
Is it a diesel and if so is it just continuing a partially started dpf regen when you stop? My Audi does this now and again.
If not, I guess it’s a faulty thermostat which is making the car think that the fans need to continue running to cool down. Unless the car really is running too hot. What does the temp gauge show? Normal? I think you probably need to take it to a garage if it’s not a dpf regeneration.
